Full loaded Savage
    • Full loaded Savage
      dann versuch ich es halt mal so:
      was haltet ihr von dem Truck?den will ich mir villeicht kaufen.
      HPI Lightweight tranny gears installed! Hitec HS5645MG FAST 168OZ metal gear steering servo! Standard Throttle/Brake Servo! Envy Racing Vented Flywheel (3 shoe clutch)
      1.
      RC Solutions Roll cage
      2.
      Hot Bodies Feather Weight Carbon Fiber TVP's
      3.
      Picco .26 Outlaw Motor Ran Odonnel20% has had 12tanks throught it so not even a gallon yet, it is most likely still going to need a little more time to be FULLY broken in and loosen up!
      4.
      HPI Threaded Shocks with/RC Trix Lightweight 3.2lb Springs for extreme handeling!
      5.
      GPM Dual Stinger Pipe
      6.
      Motor Saver Style Air Filter
      7.
      Ofna 1400MAH Battery IN THE TRUCK, including another one with the truck they have been PLASTI Dipped to seal them from moisture...
      8.
      Pigtail and battery tray cutout to charge the battery while it is still in the truck!
      9.
      4 Spyder gear mod FRONT AND REAR using 3000 WT Mugen Silicon Differential Oil
      10.
      GPM Shock Towers Front and Rear
      11.
      GPM Titanium Turbo Vent Disc Brake
      12.
      GPM Brake Nut
      13.
      GPM Purple Aluminum Bulkhead Sides Just Rear
      14.
      GPM Front and Rear Box Braces
      15.
      GPM Front and Rear ARM Lock Plates
      16.
      GPM Motor Mount Plate!
      17.
      HPI Stainless Steel Hardware Kit USED throughout the entire Truck!
      18.
      Dynamite Fuel Filter
      19.
      HPI Lightweight Tranny gears!
      20. Envy Racing VENTED 3 Shoe Clutch/Flywheel Set
      Spare parts will include Upper and Lower arm sets, Front Skidplate, Bulkhead Set, Brand New Pullstart for the Picco motor, NOW ITS USING ROTO START, i am INCLUDING AN HPI ROTOSTARTER AND EPIC BATTERY, brand new set of Clutch Shoes OFNA 1400 Battery one is in the truck this is a SPARE! A charger for the 1400MAH NiMi batterys! 1 18tooth clutchbell, 1 16 tooth clutchbell... Keep in mind this truck must sell i am firm on price being that i have over 2600 invested into this! It is by no means a "Shelf Queen" its made to hold together and be "bashed with" all HPI savage week links have been fixed to overkill standards!!!
        (37,39 kB, 275 mal heruntergeladen, zuletzt: )
        (38,41 kB, 275 mal heruntergeladen, zuletzt: )
    • oder den???
      Stock Features:
      * Nitro Star S-25 engine (ABC) with slide carburetor
      * Adjustable disc brake
      * Wide-track suspension (nearly 17 inches wide!)
      * Stainless steel inboard hinge pins with anodized aluminum braces
      * 8 long stroke oil-filled coilover shock absorbers
      * Rigid aluminum TVP chassis (Twin Vertical Plates)
      * Large 160cc primerless fuel tank
      * Enclosed radio box for protection of electronics
      * Front and rear skidplate bumpers
      * Adjustable body posts (with an extra mount for SUV bodies)
      * Chrome 5 spoke wheels and all-terrain tires with inner foam
      * Purple anodized, billet aluminum heatsink engine head
      * Adjustable upper arms with thick steel turnbuckles
      * Stiff purple shock springs
      * Pre-trimmed unpainted Nitro GT-1 truck body with pre-cut decals
      * Giant 1/8th scale (16.8" x 21")
      * 40+ miles an hour!
      * Full-time shaft driven four wheel drive
      * Complete set of rubber sealed ball bearings
      * High performance aluminum ribbed tuned pipe
      * Aluminum high flow tube rear exhaust header
      * Cast aluminum heavy-duty engine mount
      * Heavy-duty drivetrain and suspension optimized for big-block engines
      * Hardened metal differential gears
      * Extra tuning gears for off-road and on-road performance
      * Heavy-duty chromed steel dogbones
      * Adjustable 2 speed transmission with heavy-duty metal internal gears
      * Adjustable slipper clutch
      * Compatible with T-Maxx bodies
      * Compatible with T-Maxx wheels
      * Compatible with T-Maxx tires
      Modifications:
      · 05 Fantom FR 27 w/Turbo Plug
      · 1” Extended TVPs (Stock TVPs also included)
      · Aluminum Shock Towers
      · Extended Titanium Dog Bonz
      · Venom Digital Temp. monitor
      · GPM Dual Chamber Tuned Pipe
      · Aluminum Shocks
      · HPI 3 Shoe Aluminum Clutch set
      · 4 Spider Diffs
      · Braided Fuel Line
      · Motor Saver Air Filter
      · Throttle and Brake Mod (Increases response performances)
      · 6.5” UFO Wheels w/Mayhem Tires
      · Upgraded Aluminum Steering Servo Saver
      · In-Line Fuel Filter
      · Brand New Aluminum Fly Wheel
      · Extra wheel nuts and Diff rebuild kits NIP.
      · Rechargeable Hump Pack w/extra pig tail (no need to remove to charge)
      · Dual Disc Brakes
      · 13 tooth clutch bell
      OFNA Fail Safe
      HS645MG Metal Gear High Torque Servo
      Black podwer coated steel roll cage ( to protect the goodies)
      Extra Accessories:
      * Original TVPs
      * Extra set of Swamp Dogs w/Sayeville Tires
      * JR XS-3 FM Synthesized Radio 75MhZ w/ rechargeable OEM JR battery pack and charger (nice case included)
      * Charger for both Hump pack and transmitter simultaneously
      * 48 Tooth spur gear
      * Rechargeable Glow Ignitor
      * 3 bodies
      * Roto Start w/2 Battery packs
      * Super Brain 819 AC/DC Charger
      * NIP Bevel Gear set
      * A case to travel with all the items you'll need safely
      …And more
        (22,32 kB, 265 mal heruntergeladen, zuletzt: )
        (34,2 kB, 264 mal heruntergeladen, zuletzt: )
        (23,99 kB, 264 mal heruntergeladen, zuletzt: )
    • oder als letztes vielleicht den hier???
      LIKE NEW - HPI SAVAGE 25
      THAT HAS BEEN UPGRADED WITH A TRUCKZILLA FRAME KIT ONLY - NOT THE ENGINE.
      COMES WITH 2 BODIES. 1 NEW RED SAVAGE 25 BODY AND A LIGHTLY USED PURPLE/SILVER SAVAGE BODY WITH SAVAGE 25 STICKERS.
      A RECHARGEABLE HUMP PACK WITH CHARGER IN THE TRUCK .
      DUAL DISK BRAKE INSTALLED.
      INTEGEY HEX TOOL SET OF 6
      HOBBICO MULTI - CHARGER CHARGER 905
      MOTOR SAVER AIR CLEANER. WITH OIL BOTTLE
      GEAR OIL BRAND NEW
      3 PIECE TYPE. HPI ROTO START INSTALL.
      A NOVA RACING COOLING HEAD.
      HPI UPRIGHT SET NEW IN PLASTIC
      NEW 49T & 52 SPUR GEAR
      14 TOOTH IS INSTALLED
      15 TOOTH CLUTCH NEW
      18 TOOTH CLUTCH NEW
      HPI ALUM RIBBED TUNED PIPE INSTALLED.
      JUST PUT NEW SPRINGS ON PURPLE.
      I AM ALSO INCLUDING THESE EXTRA PARTS-
      OFNA FAIL SAFE INSTALLED
      OFNA SERVO SAVER SET NEW IN PACKAGE
      A GLOW PLUG HEATER AND CHARGER
      ROTOR START WITH BATTERY PACK AND CHARGER
      THE OLD SPRING 8 OF THEM (USED)
      2 NEW HPI STEERING KNUCKLE
      ATOMIK MICROTEMP TEMPERATURE GUAGE
        (46,32 kB, 250 mal heruntergeladen, zuletzt: )
        (48,62 kB, 252 mal heruntergeladen, zuletzt: )
        (43,41 kB, 248 mal heruntergeladen, zuletzt: )
        (38,25 kB, 254 mal heruntergeladen, zuletzt: )
