Welcher Truck?
    • Welcher Truck?
      Ok, vielleicht könnt ihr mir einen rat geben!?
      welchen der trucks soll ich nehmen?
      EX. COND. SAVAGE SS 4.6 - less than 1 gal. of fuel ran through it, properly broken in, this was my 6th veh. so I know the importance of breaking in a new eng. Super fast, wheelys on command, that's why their is a scrape on the head, the body was off and I didn't realize how powerful it was and it flipped over. Go to HPIRACING.com and you can read all about this rocket. It has a 2 speed tranny, and a XR3i FM JR radio system was installed with a HITEC metal gear steering servo and adjustable aluminum shocks, the shocks are brand new never ran. Included with this truck is a Duratrax Double Battery Roto Start with batteries, a Dynamite glo plug ignitor with charger and the original pull start. So all you need is fuel, 4AAA batteries, a battery charger for the roto start and quick reflexis. A reverse option is available from HPI and can easily be hooked up. I'm getting into R/C boats so I'm saying by to the land vehicles. Do the math and you will see that this is a STEAL at my BUY IT NOW price.My reserve is my BUY IT NOW price. Any ?'s just ask...
      You can buy a Savage SS new in box cheaper but you have to put it together and BUY a radio and servos. Plus if you want a Roto Start and Glo Stick...Well you get the idea. Buy Now and SAVE!!! My Reserve is $550.00. If you can add, MY LOSS YOUR GAIN.
      FÜR 610 Dollar inkl versand
        (25,37 kB, 261 mal heruntergeladen, zuletzt: )
        (25,37 kB, 263 mal heruntergeladen, zuletzt: )
        (25,59 kB, 262 mal heruntergeladen, zuletzt: )
    • oder den???
      This is a used HPI SAVAGE SS . I purchased it and found I do not have the time to spend on such a vehicle. I am getting a smaller stadium truck that I can race my son with. I will ship this within 24 hours of payment though Paypal ONLY. If you have any QUESTIONS PLEASE FEEL FREE TO EMAIL ME !!
      Stock Features:
      * Nitro Star S-25 engine (ABC) with slide carburetor
      * Adjustable disc brake
      * Wide-track suspension (nearly 17 inches wide!)
      * Stainless steel inboard hinge pins with anodized aluminum braces
      * 8 long stroke oil-filled coilover shock absorbers
      * Rigid aluminum TVP chassis (Twin Vertical Plates)
      * Large 160cc primerless fuel tank
      * Enclosed radio box for protection of electronics
      * Front and rear skidplate bumpers
      * Adjustable body posts (with an extra mount for SUV bodies)
      * Chrome 5 spoke wheels and all-terrain tires with inner foam
      * Purple anodized, billet aluminum heatsink engine head
      * Adjustable upper arms with thick steel turnbuckles
      * Stiff purple shock springs
      * Pre-trimmed unpainted Nitro GT-1 truck body with pre-cut decals
      * Giant 1/8th scale (16.8" x 21")
      * 40+ miles an hour!
      * Full-time shaft driven four wheel drive
      * Complete set of rubber sealed ball bearings
      * High performance aluminum ribbed tuned pipe
      * Aluminum high flow tube rear exhaust header
      * Cast aluminum heavy-duty engine mount
      * Heavy-duty drivetrain and suspension optimized for big-block engines
      * Hardened metal differential gears
      * Extra tuning gears for off-road and on-road performance
      * Heavy-duty chromed steel dogbones
      * Adjustable 2 speed transmission with heavy-duty metal internal gears
      * Adjustable slipper clutch
      * Compatible with T-Maxx bodies
      * Compatible with T-Maxx wheels
      * Compatible with T-Maxx tires
      Modifications:
      · 05 Fantom FR 27 w/Turbo Plug
      · 1” Extended TVPs (Stock TVPs also included)
      · Aluminum Shock Towers
      · Extended Titanium Dog Bonz
      · Venom Digital Temp. monitor
      · GPM Dual Chamber Tuned Pipe
      · Aluminum Shocks
      · HPI 3 Shoe Aluminum Clutch set
      · 4 Spider Diffs
      · Braided Fuel Line
      · Motor Saver Air Filter
      · Throttle and Brake Mod (Increases response performances)
      · 6.5” UFO Wheels w/Mayhem Tires
      · Upgraded Aluminum Steering Servo Saver
      · In-Line Fuel Filter
      · Brand New Aluminum Fly Wheel
      · Extra wheel nuts and Diff rebuild kits NIP.
      · Rechargeable Hump Pack w/extra pig tail (no need to remove to charge)
      · Dual Disc Brakes
      · 13 tooth clutch bell
      OFNA Fail Safe
      HS645MG Metal Gear High Torque Servo
      Black podwer coated steel roll cage ( to protect the goodies)
      Extra Accessories:
      * Original TVPs
      * Extra set of Swamp Dogs w/Sayeville Tires
      * JR XS-3 FM Synthesized Radio 75MhZ w/ rechargeable OEM JR battery pack and charger (nice case included)
      * Charger for both Hump pack and transmitter simultaneously
      * 48 Tooth spur gear
      * Rechargeable Glow Ignitor
      * 3 bodies
      * Roto Start w/2 Battery packs
      * Super Brain 819 AC/DC Charger
      * NIP Bevel Gear set
      * A case to travel with all the items you'll need safely
      …And more
        (30,16 kB, 257 mal heruntergeladen, zuletzt: )
        (34,2 kB, 257 mal heruntergeladen, zuletzt: )
        (23,99 kB, 259 mal heruntergeladen, zuletzt: )
    • oder den???
      This is for one very slightly used Traxxas Revo. It is highly upgraded. It has the Sirio .23 motor it in with a ton of compression left, paid 309.0 at my shop. truck has about 1.5 gallons of 20% through it. This motor is actually two quick for the track I run at. It is a small track and the Sirio .23 only gets to use half of its power. I put in the FOC kit, new front and rear complete differentials. Orignals included. They were not bad but I replaced to get back to 100% condition, this was done just 2 weeks ago. Red anodized turnbuckels and tie rods. The red set up for all 8 peices was over 100.0 alone, plus all the orignal stock ones. 2 bodies, 2 sets of tires, trinity hi-flow pipe, RC solutions aluminum roll cage 119. I put in a Integy 3 piece aluminum clutch 2 weeks ago, also bought the slipper clutch rebuild kit, but is not installed yet and is still in the bag. Spare fuel tank. Plus all the parts you see in this pictures, I may have forgotten some things, so ask questions if you want. You will have to add your own radio and receiver. I recently bought 2 mugen prospec buggies, converting one to a truggy, that is why I am selling. I also have a 2 month old JR xs3 controller and 2 rs300 receivers. I had planned on keeping for the 2 Mugen buggies I have but I might buy the M11 with the spektrum set up. If BUY IT NOW is used the winning bidder will also get the Jr xs3 and 2 rs300 receivers.
        (50,33 kB, 243 mal heruntergeladen, zuletzt: )
        (49,71 kB, 247 mal heruntergeladen, zuletzt: )
        (41,7 kB, 248 mal heruntergeladen, zuletzt: )
        (50,49 kB, 254 mal heruntergeladen, zuletzt: )
    • oder den???
      Up for auction is a used HPI Savage. This truck has been well maintained and is in excellent shape. It has been hopped-up with the following:
      - Integy front and rear bulk heads
      - Integy lower arms
      - Integy adjustable upper arms
      - Integy type 2 shock towers front and rear
      - Nova Pro Race cooling head
      - 1400 NiMh rechargeable receiver pak
      - 3 speed transmission
      - Reverse module
      - HiTec 645 mg ultra torque steering servo
      - Futaba S3003 throtle servo
      - JR XR3i FM computer racing system with receiver (3 channel)
      - complete set of stock lower arms, adjustable upeer arms, bulk heads, shock towers
      - painted body in excellent condition
      - instruction manual and spare stickers
      The 4.6 engine has the pull start. It has about a gallon of 20% through it with proper break in.As you can see from the pictures, this truck has been well maintained and is ready to rip. Please e mail me with any questions. Thanks for looking.
        (34,09 kB, 239 mal heruntergeladen, zuletzt: )
        (32,4 kB, 236 mal heruntergeladen, zuletzt: )
        (25,41 kB, 234 mal heruntergeladen, zuletzt: )
        (29,7 kB, 232 mal heruntergeladen, zuletzt: )
      in einem anderem Forum ging es um die Futaba T3PK mit 2,4 Ghz Technologie, also die Spektrum, aus den USA.
      Dazu wurde folgendes Geschrieben.
      Ich habe nun mal bei Spektrum nachgefragt und die folgende Antwort
      erhalten:
      Zitat:
      The modules sold in Germany are exactly the same as those sold
      in the US. They do not have a lower output power. Speed is one of the
      differences in the new Futaba HRS system. You also must use digital
      servos with it, and it is not compatible with the Spektrum Telemetry
      system.
      Das hoert sich also gut an!
      Holger
