D'oh nein - und ich veräußere schon meine - gedacht - überflüssigen Lenkhebel :ohmann:
XRAY T3 2012
Jetzt ist er online...Supported by
Serpent
Gens Ace
Xceed
Tonisport -
Puu ein Glück es gibt schon Tuningteile
zwar nur ein paar, aber der Hudy macht das schon.
ID Name
301159 Alu Countersunk Shim (4)
301159-O Alu Countersunk Shim - Orange (4)
301203 Impact-Absorbing Front Bumper
301213 Upper Holder for Bumper - 2.5mm Graphite
301223 Foam Bumper - Hard
301322 Front Body Mount Set 6mm
301323 Front Body Mount Set +1mm Height
301332 Rear Body Mount Set 6mm
301333 Rear Body Mount Set +1mm Height
302033 Alu Nut for Suspension Holder (2)
302033-O Alu Nut for Suspension Holder - Orange (2)
302048-O T3 Alu Lower Rear Suspension 1-Piece Holder - Orange
302077 Set of Eccentric Composite Hubs ''1'' (4+2)
302161 Front Suspension Arm - Hard
302162 Front Suspension Arm - Extra-Hard
302164 Front Susp. Arm - Extra-Hard - 1-Hole
302165 Composite Front Susp. Arm 2-Hole - Hard
302166 Composite Front Susp. Arm 2-Hole - X-Hard
302252 Composite Steering Block - Medium - V2
302256 Alu Steering Block
302295 Ball-Bearing Composite Bushing (4)
302296 Composite C-Hub Bushing (2+2)
302334 Alu C-Hub Front Block - Caster 0°
302335 Alu C-Hub Front Block Right - Caster 2°
302336 Alu C-Hub Front Block Left - Caster 2°
302337 Alu C-Hub Front Block Right - Caster 4°
302338 Alu C-Hub Front Block Left - Caster 4°
302339 Alu C-Hub Front Block Right - Caster 6°
302340 Alu C-Hub Front Block Left - Caster 6°
302343 Composite C-Hub Front Block, Right - 2° Deg.
302344 Composite C-Hub Front Block, Left - 2° Deg.
302345 Composite C-Hub Front Block, Right - 4° Deg.
302346 Composite C-Hub Front Block, Left - 4° Deg.
302347 Composite C-Hub Front Block, Right - 6° Deg.
302348 Composite C-Hub Front Block, Left - 6° Deg.
302361 Composite C-Hub Right - 2° Deg. - Medium
302362 Composite C-Hub Left - 2° Deg. - Medium
302365 Composite C-Hub Right - 6° Deg. - Medium
302366 Composite C-Hub Left - 6° Deg. - Medium
302371 Composite C-Hub Right - 2° Deg. - Hard
302372 Composite C-Hub Left - 2° Deg. - Hard
302373 Composite C-Hub Right - 4° Deg. - Hard
302374 Composite C-Hub Left - 4° Deg. - Hard
302375 Composite C-Hub Right - 6° Deg. - Hard
302376 Composite C-Hub Left - 6° Deg. - Hard
302401 Anti-Roll Bar Front (Set)
302482 Anti-Roll Bar Front 1.2mm
302483 Anti-Roll Bar Front 1.3mm
302485 Anti-Roll Bar Front 1.5mm
302486 Anti-Roll Bar Front 1.6mm
302488 Anti-Roll Bar Front 1.8mm
302610 Adj. Steering Rod L/R 40mm - Hudy Spring Steel™ (2)
302612-O Alu Adjustable Turnbuckle 39mm M3 L/R - Orange (2)
303061 LiPo Chassis Graphite Motor Guard
303071 Belt Tensioner Set T2'007, T2'008, T2'009, T3
303120 Set of Alu Shim (0.5mm, 1.5mm, 2.5mm)
303121 Set of Alu Shim (1.0mm, 2.0mm, 3.0mm)
303122 T2 Alu Shim 3x6x1.0mm (10)
303122-O T2 Alu Shim 3x6x1.0mm - Orange (10)
303123 T2 Alu Shim 3x6x2.0mm (10)
303123-O T2 Alu Shim 3x6x2.0mm - Orange (10)
303134 Alu Shim for Lower Susp. Holder 3x7.5x1.5 (10)
303141 Alu Shim 3x5x1.0 (10)
303161 Rear Suspension Arm - Hard
303162 Rear Suspension Arm - Extra-Hard
303164 Composite Rear Susp. Arm 1-Hole - Extra-Hard - V2
303165 Composite Rear Susp. Arm 2-Hole - Hard
303166 Composite Rear Susp. Arm 2-Hole - X-Hard
303210 Rear Turnbuckle L/R 25mm - Spring Steel (2)
303212-O Alu Adjustable Turnbuckle 26mm M3 L/R - Orange (2)
303351 Composite Upright 1° Outboard Toe-In - Right - Medium
303353 Composite Upright 1° Outboard Toe-In - Right - Hard
303354 Composite Upright 0° Outboard Toe-In - Hard
303358 Alu Upright Rear 1° Outboard Toe-In (L+R)
303359 Alu Upright Rear 2° Outboard Toe-In (L+R)
303361 Composite Upright 1° Outboard Toe-In - Left - Medium
303362 Composite Upright 0° Outboard Toe - Medium - 1-Hole
303363 Composite Upright 1° Outboard Toe-In - Left - Hard
303364 Composite Upright 0° Outboard Toe - Hard - 1-Hole
303401 Anti-Roll Bar Rear (Set)
303440 Alu Anti-Roll Bar Collar (2)
303481 Anti-Roll Bar Rear 1.1mm
303483 Anti-Roll Bar Rear 1.3mm
303484 Anti-Roll Bar Rear 1.4mm
303485 Anti-Roll Bar Rear 1.5mm
303486 Anti-Roll Bar Rear 1.6mm
304971 Differential Outdrive Adapter - HUDY Spring Steel™ (2)
305003 Alu Ball Differential 34T + 38T Pulley - 7075 T6 - Set
305012-K Alu T6 Diff Long Output Shaft - Hard Coated - Black
305022-K Alu T6 Diff Short Output Shaft - Hard Coated - Black
305040 Screw For External Diff Adjustment
305052 Diff Pulley 34T with Covers
305054 Diff Pulley 34T with Labyrinth Dust Covers
305058 Diff Pulley 38T with Labyrinth Dust Covers
305080 Diff Washer + Ball Steel 2.4mm ( 2+12 ) Set
305082 Diff Washer 17x23x1 (2)
305105 XRAY Multi-Differential T3 LiPo
305117 Multi-Differential Main Axle T3 LiPo
305121 Multi-Diff Locking Axle - Spring Steel
305132 Inner Driveshaft Adapter 3.5mm - Spring Steel (2)
305136 Alu Solid Axle Driveshaft Adapters (2) - Hard Coated
305137 Solid Axle Driveshaft Adapter - HUDY Spring Steel™ (2)
305150 Timing Belt Pulley 34T for Multi-Diff
305158 Timing Belt Pulley 38T for Multi-Diff
305184 Composite Solid Axle 34T - Set
305225 ECS Drive Shaft 50mm - HUDY Spring Steel™
305227 ECS Drive Shaft 52mm - HUDY Spring Steel™
305250 ECS Drive Shaft Case - Hudy Spring Steel™
305251 ECS Drive Shaft Coupling - Hudy Spring Steel™
305323 Drive Shaft 50mm - Hudy Spring Steel™
305325 Equalized Corner Speed (ECS) Drive Shaft 50mm - Hudy Spring Steel™ (1)
305327 Equalized Corner Speed (ECS) Drive Shaft 52mm - Hudy Spring Steel™ (1)
305328 Alu Drive Shaft Swiss 7075 T6 - Hard Coated - 50mm
305340 Drive Axle – Hudy Spring Steel™
305351 Alu Wheel Hub - Offset -0.75mm (2)
305352 Alu Wheel Hub - Offset +0.75mm (2)
305353 Alu Wheel Hub - Offset +1.5mm (2)
305380 Alu Wheel Shim Offset 0.75mm (2)
305390 ECS Drive Shaft Pin 1.5 x 8.5 - V3 (2)
305391 ECS Drive Shaft Pin 1.5 x 9 (2)
305392 Drive Shaft Pin 2x10 with Flat Spot (2)
305431 High-Performance Kevlar Drive Belt Front 3x507mm
305444 High-Performance Kevlar Drive Belt Rear 3x183mm
305521-O Alu Solid Layshaft - Orange
306163 6-Cell Graphite Battery Strap w/ Alu Stands (Set)
306163-K Graphite Battery Strap for LiPo/NiMH - Black - Set
306186 Alu LiPo Battery Backstop (F+R)
306200 Alu Servo Mount (2)
308031 Alu Shock Spring Retaining Collar (4)
308031-O Alu XRAY Shock Spring Retaining Collar - Orange (4)
308036 Composite Non-Adjustable Pistons - V2
308040 Shock Adj. Nut Alu + O-ring
308080 Shockabsorber Membranes (4)
308090 Shock Foam Inserts (4)
308302 XRAY Shock Absorber-Set 4-Step - Short (2)
308306 XRAY Alu Shock Absorber - Set (2)
308306-O XRAY Alu Shock Absorber - Set - Orange (2)
308322 Alu XRAY Shock Body For #308306 (2)
308327 Alu Cap For XRAY Shock Body #308322
308327-O Alu Cap For XRAY Shock Body #308322 - Orange
308352 Alu Shock Cap-Nut with Vent Hole (2)
308363 Hardened Shock Shaft for Alu Shock (2)
308373 XRAY Spring-Set C = 2.2 (2)
308374 XRAY Spring-Set C = 2.4 (2)
308376 XRAY Spring-Set C = 2.8 (2)
308378 XRAY Spring-Set C = 3.2 (2)
308379 XRAY Spring-Set C = 3.4 (2)
308380 Additional XRAY Ultimate Racing Springs (20)
308382 XRAY Spring-Set D=1.4 (14 LB) Gold (4)
308383 XRAY Spring-Set D=1.5 (17.5 LB) Silver (4)
308384 XRAY Spring-Set D=1.5 (15 LB) Blue-Green (4)
308385 XRAY Spring-Set D=1.6 (20 LB) Light-Blue (4)
308386 XRAY Spring-Set D=1.7 (25 LB) Dark-Blue (4)
308387 XRAY Spring-Set D=1.8 (30 LB) Light-Purple (4)
308388 XRAY Spring-Set D=1.9 (35 LB) Light-Red (4)
308390 XRAY Selected Ultimate Racing Springs (24)
308393 XRAY Spring-Set D=1.4 (14 LB) Yellow - Super Soft (4)
308394 XRAY Spring-Set D=1.5 (17.5 LB) White - Soft (4)
308395 XRAY Spring-Set D=1.6 (22.5 LB) Blue - Soft-Medium (4)
308396 XRAY Spring-Set D=1.7 (28 LB) Violet - Medium (4)
308397 XRAY Spring-Set D=1.8 (33 LB) Purple - Medium-Hard (4)
308398 XRAY Spring-Set D=1.9 (38 LB) Red - Hard (4)
309002 T3'11 Set of Ceramic Ball Bearings (14)
309500 Silicone Grease 00
309520 Silicone Oil 20W
309550 Silicone Oil 50W
309840 Precision Balancing Chassis Weights (4 pcs.)
309850 Balancing Chassis Weights (Center - 3 pcs)
309853 Precision Balancing Chassis Weights Center 20g
309854 Precision Balancing Chassis Weights Center 30g
309901 XRAY Aluminum 1/10 Touring Set-Up Board - Limited Edition
338286 XRAY Springs - Set D=1.7 (25 LB) Dark-Blue - Soft-Medium - Rear (2)
338287 XRAY Springs - Set D=1.8 (30 LB) Light-Purple - Medium-Medium-Hard - Rear (2)
338288 XRAY Springs - Set D=1.9 (35 LB) Light Red - Hard - Rear (2)
338296 XRAY Springs - Set D=1.7 (28 LB) Violet - Medium - Rear (2)
338297 XRAY Springs - Set D=1.8 (33 LB) Purple - Medium-Hard - Rear (2)
359210 XRAY Premium Silicone Oil 100 cSt
359215 XRAY Premium Silicone Oil 150 cSt
359220 XRAY Premium Silicone Oil 200 cSt
359225 XRAY Premium Silicone Oil 250 cSt
359230 XRAY Premium Silicone Oil 300 cSt
359240 XRAY Premium Silicone Oil 400 cSt
359245 XRAY Premium Silicone Oil 450 cSt
359250 XRAY Premium Silicone Oil 500 cSt
359255 XRAY Premium Silicone Oil 550 cSt
359260 XRAY Premium Silicone Oil 600 cSt
359280 XRAY Premium Silicone Oil 800 cSt
359290 XRAY Premium Silicone Oil 900 cSt
359301 XRAY Premium Silicone Oil 1000 cSt
359302 XRAY Premium Silicone Oil 2000 cSt
359398 XRAY Premium Silicone Oil 300 000 cSt
901310 Hex Screw SB M3x10 (10)
930120 Carbide Ball 2.4mm (12)
930138 Carbide Ball-Bearing Axial F3-8 3x8x3.5
930220 Ceramic Ball 2.4mm (12)
930238 Ceramic Ball Bearing Axial F3-8 3x8x3.5
963030 Cone Washer ST 3x8x0.5 (10)
966080 CH-Clip 8 (10)
970100 O-Ring 10x1.5 (10)Blue ist better! -
das wird schon werdenendlich muss ich manch ein depp vom hpi lrp challange nicht mehr sehen
das waren schon alle tuningteile?????
dachte kommen mehrGruß
Chris
ARC R10 2013 mit LRP Flow & X20 17,5Turn
Ansmann X2TE mit SPX Zero & X20 13,5Turn
Tamiya TA04 S mit Vectra B I500 Karosse wie mein Echter Standmodell -
Ist doch schön, dass die ganzen alten Teile noch passen.Supported by
Serpent
Gens Ace
Xceed
Tonisport -
Hallo David,
mir will jemand erzählen, das mann einen '11 nicht auf die Chassisplatte vom '12 aufbauen kann,
dem ist doch wohl nicht wirklich so....................., oder? :ka:
Ist das neue Oberdeck in Verbindung mit der Chassisplatte eher für Asphalt oder Teppich geeignet?
Gruß,
Markus -
Störsender TM schrieb:
Hallo David,
Gruß,
Markus
So wie ich das sehe geht das schon.
Viele Grüße Dirk -
Hi, es gibt auch eine chassi Platte von Exotek was auch das Servo wie bei dem T3 2012Xray T4 20 - Sanwa M12 - LRP FlowX - LRP HV 6400 - MuchMore 17,5 - MSC Pol. Braunschweig
Hallo David,
Gruß,
Markus
Habe gerade mal auf die Referenztabelle geschaut,
dort steht tatsächlich nicht, das man das '12 Chassis auch für einen '11 Bausatz verwenden kann,
nicht einmal die Doppelanlenkungs-''Arme''...........................
Das ist wirklich nicht schön.
Gruß,
Markus -
Und ich sage immer noch für mich geht das :ka: :ka:
Gruß Dirk -
Die Doppellenkungsarme und das Chassis muss man zusammen verwenden. Dann geht es. Es passen nur nicht die 11er Doppellenkungsarme mit dem 12er Chassis zusammen und umgekehrt.
Man kann die 11er Doppellenkungsarme aber modifizieren, so dass es geht (zusätzliche Bohrung rein).
Ach ja, und die 11er Lenkung passt auch nicht mit dem 12er Topdeck (weil der Servosaver ja in der Mitte sitzt, und das 12er Topdeck da keine Öffnung hat).Supported by
Serpent
Gens Ace
Xceed
Tonisport -
Genau so wie David es geschrieben hat meinte ich es. Es haben ja schon viele ihr Servo um 90 Grad in dem 11er
eingbaut daher brauchen die eigentlich nur das Chassis und das neue Topdeck.
@david warum sind denn jetzt wieder die alten Lenkhebel im Baukasten mit weniger Lenkeinschlag ????
Gruß Dirk -
Weil der Lenkausschlag mit 26° immer noch der größte aller verfügbaren Tourenwagen ist, und die 32° dazu verleitet haben, dass man gedacht hat, man hätte mehr Lenkung, in Wahrheit hat sich das Auto aber nur mehr selbst abgebremst.Supported by
Serpent
Gens Ace
Xceed
Tonisport -
Hi David,
Vielen dank .... :winke: :winke:
Gruß Dirk -
Hallo David und Dirk,
nun habe ich den durchblick.....................
danke euch beiden!
Gruß,
Markus -
Hi Markus,
Kein Thema :winke: -
ab wann im handel erhältlichendlich muss ich manch ein depp vom hpi lrp challange nicht mehr sehen
Benutzer online 71
71 Besucher
