Hier sind zwar nicht sonderlich viele Rennbegeisterte Offroader und die Klasse ist in Deutschland gerade erst im kommen, aber den sollte man keinem vorenthalten!
Für mich ist er der Kandidat für die nächste Saison - zumindest wenn HPI nichts am Antriebsstrang vermurkst
Quelle: hpiracing.com/hellfire/ (Dort sind auch mehr Bilder mit hoher Auflösung!)
Coming soon from HPI Racing is the Hellfire, a purpose built, Ready-to-Run high performance, 1/8 scale four wheel drive monster truck. The Hellfire offers maximum performance in all conditions by combining the durability characteristics of the Savage with the agility of 1/8 scale buggies. The truck has a wide range of tuning adjustments, is extremely lightweight and features all-new suspension and steering geometries. It has been designed to allow for easier maintenance with simplified differential access, high quality hex hardware and no e-clips are used anywhere.
The Hellfire will sit along side the Savage in the HPI monster truck line-up. The Hellfire is fast, low and aimed at track enthusiasts, while the Savage is a proven “basher” with oversized durability and maximum ground clearance. Both trucks will be available in ready-to-run and kit versions.
Due for release before the end of the year, stay tuned for more information on the Hellfire.
Hellfire features:
• Purpose built high performance monster truck right out of the box. This is not a buggy conversion!
• Internal drive ratio is optimized for .21 and .28 size race engines.
• Steering and suspension geometries are designed specifically for this truck to maximize performance.
• Low center of gravity for increased responsiveness and better chassis balance.
• The front and rear differentials can be removed by taking out six screws.
• The removal of four screws allows access to the center differential.
• No e-clips are used, anywhere!
• Hex sockets reduce the possibility of a stripped screw.
• Adjustable front and rear inboard toe with convenient urethane eccentric bushings.
• Front inboard toe angle adjustments: 0 degrees to -2 degrees.
• Rear inboard toe angle adjustments: 2 degrees to 4 degrees.
• Adjustable front and rear camber using strong steel turnbuckles.
• The camber can be fine tuned to suit your track conditions.
• Anti-dive adjustments: 0 degrees to 2 degrees in 0.5 degree increments.
• Anti-squat adjustments: 1.5 degrees to 3.5 degrees in 0.5 degree increments.
• Front kick-up angle: adjustable from 21 to 25 degrees.
• 24 possible shock positions available to fine tune your suspension.
• Spring clips are included to fine tune your ride height.
• Four different shock pistons are included for a wide range of tuning options.
• Different compression and rebound can be achieved with tapered shock pistons.
• Damping can be fine tuned with different diameter holes.
• Adjustable steering geometry.
• Adjustable brake bias to control entry steering and jumping.
• Chassis braces included to adjust overall chassis stiffness for smooth or bumpy tracks.
• New, high RPM .28 K4.6 HO engine with increased HP and torque.
• Hard anodized exhaust pipe for maximum power.
• High flow 2 stage air filter for maximum engine protection and increased engine performance.
• Continuous radius exhaust header for maximum exhaust flow and power.
• Wire routing protects wires from moving parts.
• Fuel tube routing system prevents line breakage and promotes better fuel delivery.
• Fuel splash guard keeps fuel splashes away from the brake disk and drivetrain.
• 150cc fuel tank for longer run times than buggy spec 125cc equipped trucks.
• Internal fuel tank filter and external high quality fuel filter for maximum engine protection.
• Low center of gravity flush mounted radio box.
• Secure transponder mounting system.
• 1100 mah, 5-cell receiver pack with 2 hour wall charger included.
• New high strength aero dish wheel with 17mm hex for added durability.
• All driveshafts are CV style joints maximum durability and high efficiency.
• 3.5mm titanium nitride coated shock shafts for durability and maximum performance.
• Titanium nitride suspension pins are extremely durable and provide smooth suspension action.
Hellfire features:
